View Full Version : Rough-in: Will 11-3/4" cut it?
sjread
03-17-2005, 10:28 PM
Just had a bathroom tiled and the distance from the finished wall to the center of the flange is 11-3/4". Can I squeeze a standard 12" model in there? After all the rave reviews, I'm shooting for the Toto Ultramax if that makes any difference. Thanks for any info.
Scott
03-17-2005, 11:20 PM
11-1/4" will work for the Ultramax.
When the Ultramax toilet, and many toilets for that matter, you would have 3/4" of space behind the tank with a standard 12" rough-in.
jimbo
03-18-2005, 07:02 AM
I checked a number of rough sheets, and didn't find any which would not fit in 11½" or greater.
sjread
03-18-2005, 08:11 AM
Thank you both for your replies. Very good news! And thank you, Terry, for an outstanding website.
Scott
koa
04-12-2005, 03:08 PM
Of course you were right. Just got back from the dealer and it is 10 1/2" from the center of hole to the back of the toilet base. Didn't mean to doubt you. Bought the Ultramax. BTW thanks for the fast replies.
chipshot
04-18-2005, 09:57 AM
Any suggestions for toilets that will fit a 10.5" rough in? In remodeling the bath I furred out the entire side of the room for tiling around the tub. I almost soiled myself when I realized I altered that dimension. I've got exactly 10.5" rough in and am lookng for the best solution whether it be in a toilet, offset flange or some other mod. I suppose the toilet choice would work best but it seems the options are limited.
