View Full Version : "Rocking" commode
craney31
03-17-2005, 03:04 PM
I had a "rocking" commode. When I took it up I discovered that the plastic flange was broken on one side, and it is about 3/4 of an inch higher than the floor. The flange is glued inside the 4 inch drain pipe. How do I remove and replace it with one that is level with the concrete floor. Thanks. Curt Raney
Mike Swearingen
03-17-2005, 04:16 PM
Use a heavy glove and a hacksaw blade to cut the bad plastic flange into quarters. Try not to cut into the pipe.
Chip the quarters out with a hammer and chisel. Cut the pipe off level with the floor. Sand and clean up the pipe, and glue a new flange into it.
The flange should sit flush on top of the finished floor level with only the thickness of the flange above floor level. Bolt the flange to the floor.
If the toilet does not sit level (put a level across the bowl), shim it level under the base with beveled plastic shims made for the purpose.
Good luck!
Mike
craney31
03-21-2005, 07:04 PM
Thanks Mike. You've been a great help. Curt Raney
