denonymous
11-07-2007, 07:42 AM
Hi all, first-time poster. I glanced through a search but didn't find anything specific to this issue; I hope I'm not repeating anything. A brief explanation:
My fiancee and I own a split-level with one full and one 3/4 bath on the upper level and one half bath in the lower level. We've been slowly working on renovating the lower level, so we've had a couple of rooms sealed off with painter's tape for over a month (lots of sanding of paneling, so we figured we'd try to keep them as clean as possible). I know little to nothing about plumbing -- I've replaced flush handles and know the minimum one learns from buying a house with a septic, but that's about it.
Halloween night I happened to be strolling across our front lawn and thought I caught a whiff of sewage. Distressing, as there's no sewer on our street and, to boot, our septic is under the front lawn. It seemed to go away after I noticed the master bath toilet running (the chain gets caught from time to time), so I figured perhaps it vents gas when water's running or something and forgot about it.
A couple of days ago, my fiancee mentioned she thought she smelled sewage as well, but inside the house -- outside the door of the lower half bath (that's been completely sealed off with painter's tape for some time). I'd been worrying about the lack of heat in there anyway, with the falling temps here in New England, so I figured I'd break the tape and get the heat on in there a bit and investigate a possible odor. The smell was pretty powerful. The bowl was empty but for a few ounces of water in the bottom, some backed-up sludge, and some flies. I flushed twice, which took care of both the latter items, and the system seemed to be OK.
My guess here is that there's something to having some available air pressure in the room for plumbing, and over a month of flushing the other two toilets has been slowly sucking the water out of this one to the point where the septic has backed up into it a bit. Can anyone with some plumbing knowledge confirm or deny this? I'm loathe to think there's something bigger here than just needing to air that room out, give it a good cleaning, and never EVER seal off a bathroom again, but I'd like to know for sure.
Thanks in advance if anyone has any information, it's much appreciated.
