View Full Version : Air release ? in a converted gravity system
xjmllc
10-26-2007, 05:07 AM
First off, forgive me if my terminology is off.
OK, I had an original "gravity" boiler system. The old expansion tank was way up in the attic. The tank/leftover pipes are higher than any radiator. I'm concerned about the air trapped in these pipes without a radiator to bleed. Do I simply insert an air release valve like the Taco slimeline hy-vent model below. Please see diagrams.
OLD SETUP
http://www.heatinghelp.com/pics/heating_p13_194x300.gif
NEW SETUP??
http://www.xjmllc.com/images/new.jpg
http://http://www.pexsupply.com/product_dtl.asp?pID=4551&cID=305&brand=Taco
http://www.pexsupply.com/img/productImages/taco%20air%20vent.jpg
thanks!!
HvYhitter
10-26-2007, 07:58 AM
good question.. because you will never get the air out of the lines above the highest air vent in your system I am betting.
xjmllc
10-26-2007, 09:15 AM
I'm now almost certain I need to connect the pipes (based on the first picture above) it's a supply and return piping through the tank.
Still, how do I remove this air in the pipes above the highest radiator (1 floor below)????
1) Just connect the pipes
2) Connect the pipes and add an air release in between them
