View Full Version : Is this a Frost Free Spiggot/Faucet
CalgaryKid33
10-24-2007, 08:14 AM
Hi Guys,
I recently bought this house, outside tap, I am used to a shut off valve in the basement, but the basement is developed and has been for several years. There is no shut off valve inside unless it has been enclosed. So I took a picture of the ouside Faucet and I hope it is a frost free faucet. I am in Canada and temps get below -30. Sorry I should of tried to get a shot from the front, for a brand name. Anyways I am hoping one of you experts recognize it. As mentioned, the plumbing is behind a bulkhead. I would prefer not to have to tear into a wall. Any help would be greatly appreciated.
Gary Slusser
10-24-2007, 08:31 AM
I say no. A frost free faucet is like 12"+ long and the stop washer is on the far end of that long a stem.
A frost free hydrant sticks up out of the ground 3+ feet with the washer stem like 3' long to be down below the frost line in the yard.
http://www.terrylove.com/images/yardhydrant_installed.jpg
They make yard hydrants that are self draining for winter use.
CHH
10-24-2007, 08:42 AM
It's been on the house for years and hasn't frozen? It's ok then.
If you'd like to be certain, shut-off the water to the house and then unscrew the brass fitting between the handle and the hose threads. You should be able to pull out a long valve stem once it's unscrewed.
Ian Gills
10-24-2007, 08:43 AM
That is definitely not a frost-free faucet.
I am trying to install a frost free faucet at the moment and would like some advice. I would like to use a flexible stainless steel faucet supply line to connect the faucet to my copper water line.
Copper pipe from the frost free faucet will run through the wall. I will then connect the threaded end to the threaded end of my copper water line using the SS flexible line, much like you would do when installing a kitchen faucet.
Is this OK? I am doing this to make replacement of the faucet easier in the future (it will reduce the amount of soldering I need to do as well), but have never seen it done before. Usually copper pipe is connected directly to the faucet.
CalgaryKid33
10-24-2007, 09:35 AM
Yeah CHH, I assumed since it hasn't frozen yet then it should be ok. I looked everywhere for a shut off valve too. IT is a rental unit that had been rented for several years and I doubt the renters would be shutting it off anyways.
CalgaryKid33
10-24-2007, 09:43 AM
SO if I do unscrew it and it isn't a long valve, can Iget one and put it in? Or Do I have to go purchase an actual full Frost free unit?
CHH
10-24-2007, 10:02 AM
The hose bib would have to be replaced if you found a standard unit. Don't worry, you'll find a frost free sillcock.
I suspect the guys that are saying that its not frost free are allowing that cover plate to distract them. It looks to me like a normal brass body.
Another way to check is just watch the amount of water that runs out after it's shut off. If its only a little bit then it's not a freeze proof unit. If you get quarter to half a glass of water or so then the valve seat isn't near the outlet which indicates a freeze proof unit.
Bosun
10-24-2007, 10:44 AM
I had the same problem--I was a little concerned as our winters get cold too.
I did find a shut-off--it was 12 feet away! I just shut the line and opened the hose bibb--problem was solved. Make sure they didn't do something odd like this...
CalgaryKid33
10-24-2007, 10:55 AM
The hose bib would have to be replaced if you found a standard unit. Don't worry, you'll find a frost free sillcock. Sillcock and hose bib are the saem thing?.
SO hose bib is the brass body that the hose screws onto right?
I suspect the guys that are saying that its not frost free are allowing that cover plate to distract them. It looks to me like a normal brass body..
SO No way of replacing the normal valve wit ha frost free one while leaving the hose bib in place?
Peanut9199
10-24-2007, 11:19 AM
Wall Hydrant or Frost-proof wall faucet whatever you want to call it.
You do not have one what you have is a regular sediment faucets or garden hose faucet.
A wall faucets has a 1/2" thread at the end and there would be no way to get a chrome escutcheon on it (unless the flange is a spilt flange which you don't).
You can also see the thread outside which means it can be soldered or threaded and you wouldn't see that on a wall hydrant..
I can't see you living in Calgary and it not freezing if you don't stop the water getting to outside. There must be a shutoff inside somewhere. Now it may not be right beside the wall, i've seen them 10 feet away from the wall and they will have a shutoff with a drain in the side of it to drain all that water.
Ian Gills
The problem with connecting your faucet to a flex line is that it will be able to slide back and for through the wall unless you secure the hose bibb outside to the wall.
CalgaryKid33
10-24-2007, 11:32 AM
There must be a shutoff inside somewhere. Now it may not be right beside the wall, i've seen them 10 feet away from the wall and they will have a shutoff with a drain in the side of it to drain all that water..
Basement is developed and the line runs from furnace room into enclosed Bulkhead. So if there is a shut off it has been enclosed for several years. There is no shut off in furnaceroom.
Ian Gills
10-24-2007, 11:41 AM
Thanks Peanut. I will make sure I secure it both on the outside and the inside.
Peanut9199
10-24-2007, 12:52 PM
I can't see it not having a drain somewhere.
I'm in Ontario which is a bit warmer than you and last year my pipe in my garage froze and burst and it wasn't that bad last year.
You may have to open the ceiling where it's coming in the wall and install a access cover if you find one.
jadnashua
10-24-2007, 01:03 PM
If you go to the trouble to open the ceiling behind the valve, install a frost free unit, or add a shut-off. Where you live, it's just too risky to leave a normal one on unprotected. Sure there isn't an access panel hidden somewhere?
CalgaryKid33
10-24-2007, 01:12 PM
Yup no acess hatch whatsover, if the is a valve it is well hidden, from what I can see from the Furnace room down through a small hole in the Bulk head, there are two lines one must be for the tap, but it runs the full length of the bulkhead with two 6" ducts for hot air from the furnace. Liek I said this is a rental unit that I just purchased and I doubt the tenants have been shutting it down and no burst pipes, and no shut off to be seen!!
Gary Swart
10-24-2007, 02:13 PM
Not to beat a dead horse, but you do not have a frost-free valve. They are about 12" in length and screw into the supply line which is inside the house. The part of the valve that actually stops the water is in the end of that pipe just before it connects to the supply line. What makes is frost-free is that when the valve is turned off, the pipe to the outside drains. A note on this. Do not leave a hose connected to the valve in the winter. That will prevent the water from draining out and you'll have a big leak in the spring when you try to use the valve. I have no answer as to why it has not frozen before, but there must be a way the valve is turned off somewhere.
CalgaryKid33
10-24-2007, 02:51 PM
I am going to look again a little closer tonight. Like i said the lines run up against the heating duck all the way up to the outside wall so I am wondering if maybe since the heat is always on the radiant heat from the duct and keeping everything from freezing. Regardless I assume the shut off valve, if it was properly done will be located about 12-15" from the outside wall. I might cut a access panel and take a look. Otherwise I think it will be far less work to through a shut off valve on then dick around on the outside of the house.
CalgaryKid33
10-25-2007, 07:18 AM
Well I cut a hole, stuck a camera up it, lo and behold! Looks like the idiot who developed the basement left no hatch which also means that it hadn't been turned off in years. It took me quite a bit of strength to turn it off.
10-25-2007, 07:19 AM
From CHH.
A case of the blind leading the blind. Frostproof hose bibbs do not have pipe threads behind the flange, nor will a 1/2" escutcheon slide over them. This is a common hose faucet soldered to to a copper tube, so DO NOT try to unscrew it.
Peanut9199
10-25-2007, 07:25 AM
They also installed the valve with a drain which is good because you can now drain the water enough that the water won't freeze in the wall.
Peanut9199
10-25-2007, 07:34 AM
I did mention that.
The valve has a drain on the side which is good because you can now drain the water enough so the pipe won't freeze in the wall.
CalgaryKid33
10-25-2007, 07:52 AM
Yup already drained.
CalgaryKid33
10-25-2007, 08:00 AM
SO if you look at this photo, is it possible to replace the washers/ valve on this type of shut off. I see that where the red handle comes out, there are threads and a nut it looks like. OR if this thing leaks, then do you have to replace the whole thing? As well which part to you unscrew, the smaller nut in front of the handle or the larger one with the mineral build up on it?
Peanut9199
10-25-2007, 08:20 AM
It is a compression (globe) stop and it looks like a Dahl.
I know Dahl sells the replacement stem assembly for their valves.
http://www.sphcorp.com/products/dahlvalve/dahlBig/2312-44.jpg
But it may not be Dahl, their valves are normally marked with their name.
jadnashua
10-25-2007, 09:16 AM
Usually, the nut closest to the handle is for the packing; the one closer to the body is to remove the stem. You probably want to loosen the packing prior to removing the stem and slightly open the valve first. Wait for somebody that actually does this to comment.
patrick88
10-25-2007, 06:16 PM
I don't find it worth trying to fix old valves. Replace the old valve and install a nice new 1/4 turn ball valve w/drain. Install a nice new frost free sillcock w/back flow preventer. It will look much nicer and give you years of use. I so love seeing a boiler drain in place of sillcocks and laundry valves.
Cass
10-26-2007, 04:49 AM
The first pic is a boiler drain soldered to a piece of 1/2" or 3/4" copper pipe with an escutcheon added on to make it look good.
CalgaryKid33
10-29-2007, 11:31 AM
Just replaced the washer on the shut off, yes it was a Dahl shut off stopped leaking and no issues. Yes I realize that a full R/R would be more ideal,but tenants were moving in, and I actually have a full time job otherwise. Plus it was a tight fit and my soldering skills are poor at best! Otherwise thanks "Love" the site!!
Ian Gills
11-08-2007, 01:57 PM
I installed two anti-freeze garden faucets using flexible supply line to make the final connection. They are both bolted to the wall so do not move.
However, there is one drawback with using flexible stainless steel lines for this application. The faucets produce less volume of water because the diameter of the tubes is less than coppper pipe.
Gary Slusser
11-08-2007, 02:47 PM
Then you probably used braided SS rubber hose instead of flexible corrugated SS tubing...
Ian Gills
11-09-2007, 03:53 PM
Yes I have. Will this cause problems? I did it to cut down on the soldering and it will make replacement a breeze. Don't laugh, I love plumbing.
I did two faucets:
Gary Slusser
11-10-2007, 09:18 PM
Cause problems... other than low flow? Not IMO but...
It looks as if you have a kink where it is connected to the piece going through the wall. That will probably cause the line to rupture eventually. Replace it with a longer one that has no strain on it, or use an elbow so the line is straight.
Ian Gills
11-11-2007, 02:31 PM
Thanks Gary for your advice.
