View Full Version : Sink drain question
jumpyg
03-14-2005, 06:55 AM
Hi, I'm replacing a vanity/sink in my 1/2 bath. I have the old stuff out and am about to use a hole saw to cut holes in the back of the vanity for the water supply lines and the pvc waste line. The waste line has a bend in it that will have to come off. It is full of junk inside, and I want to minimize the size of the hole in the vanity back. My question is: how do I remove the bend? How close to the wall do I cut?
In my first picture below, you can see that there is a PVC fitting sticking out of the wall. Then it looks like a very small piece of pipe, then a "straight" fitting, another short piece of pipe, then the bend. I'm wondering if I should cut at point A or point B? If I cut at point A, will I be able to get all of the pipe out of the fitting coming out of the wall? Note that I'm replacing the supply valves, which gives me a little bit more room to work with the waste line.
Please advise--thanks!
03-14-2005, 07:02 AM
Cut at point "B". If you cut a point "A", there is no guarantee that you will be able to get the rest out of the fitting, and there will not be enough pipe available to make a new connection without doing so.
jimbo
03-14-2005, 07:30 AM
Agreed. Cut a "B" and cut at the point farthest away from the wall, leaving a stub to connect the new parts to.
This is a situation which probably was cut once before, possiblhy for a cleanout job, then coupled back together. Since the T is apparently right at the wall, if you cut at A you would either have to get a special bit to ream the stub out, or get into the wall to replace the T.
jumpyg
03-14-2005, 07:37 AM
Thanks a lot for the quick responses, HJ and Jimbo! That is a good idea--I definitely want to play it safe and not risk having to open up the wall.
As for cutting it--I guess a hack saw is the best bet, right? I don't have room to use my cutting tool with the cutting wheel because of the supply lines. Is there any advantage to using the PVC saws that I've seen? They just look like hack saws to me. I've also seen ratcheting cutters, but I'm not sure they are for 1.5" PVC pipes.
