Scotto
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I'd like to add a small bar sink in the basement nearby the
3" cast iron sanitary drain stack that goes to the first floor. The bar sink would be very low volume.
There is a clean-out plug ( 3 1/2" ) right next to the drain stack in the floor. Rather than breaking up the concrete,
I'd like to use a 3 1/2" to 3" adapter treaded into the
clean-out, and a 3" Sch 40 PVC wye with a clean-out plug on top
connected to the adapter. A 2" Sch 40 pipe would connect to
the sink drain, about 2 feet away. Between these would be
a tee with an atmospheric vent valve. I'd basically be raising
the clean-out plug about 12" and adding an ATM vent for the sink. Does this sound reasonable? Any code violations?
Could I use 1 1/2" PVC rather than 2" PVC for the drain pipe?
