Drum Trap
ShannonT
:eek: I am completely remodeling a small 6'3"x6'7" bathroom. I plan to replace the shower with a neo-angle tiled shower using a Kerdi shower kit. Because I'm using the Kerdi system, I needed to replace the drain.
And so my troubles begin. As I break up the slab I find that the clamping drain is attached to what appears to be a 4" pipe going straight down. So I start digging. There must be a trap somewhere, right?
About 8" down I find the connection to the vent. It is at an upward angle and is cast into the "pipe". At about 12" down, I find the bottom of the pipe. Now I am on the hunt to find out where/how the water leaves this vertical pipe. I have dug most of the way around the pipe so it must be under vent pipe.
Is this something standard for a house built in 1963?
How am I going to replace this mess with a PVC P-trap?
There is a vent, and no p-trap?
Not good. Normally, you have something like a wye on the horizontal for the vent, and the pipe on the horizontal continues for the p-trap.
You don't want an un trapped shower drain, and that smell wind that comes up the drain.
More info
:( Well, I don't know whether it is good or bad news, but I do have a drum trap. A little more hammering and a little more research on how the trap works confirms it. I was very confused when I saw only one line coming out of the vertical 4" pipe and it appeared to line up with the vent line in the wall.
I can't figure out how to post a picture or I would. I believe I can cut the drain line, put a PVC line with P-trap in and I'll be back on track. I just have to verify my elevations so the drain doesn't end up going uphill.
pipes
Your description of a "vent" connected to the vertical line, and "only one line connected to the vertical pipe", is confusing because the line should have gone down, then turned horizontally to the trap with NO PIPES connected between the drain and the trap.
Here is a picture of what I am talking about. The line going up at a 45 deg angle is the only vent or drain line. The shower drain used to be on top of that 4" vertical pipe.
At first, I assumed the 45 deg. pipe was the vent line. More digging and more research showed that this was not a vent, but the drain line. The main drain header was just 2-3 inches below the finished level level of the shower drain. As water pored into that vertical pipe/trap, the water was forced up the 45 deg pipe and out the sewer. A good system, except when it fills up with hair and crud and clogs that outlet.
" There is a good possibility that things are not as YOU ARE
describing them. "
Genisscience, That, is a classic statement !! It applies to all humans .
I can just see Dr. Phil saying this!:D
Things are as I describe. We cut the drain line where it turns horizontal at the upper left, just out of the picture. I will try and post a picture of the trap tonight.
drain
I am not sure how they made that connection in such a short space, but if there is a trap below it, then that may be some handyman's idea of a way to connect a sink drain to the sewer system.
Pictures
Here are pictures of the trap and the hole.
"I am not sure how they made that connection in such a short space, but if there is a trap below it, then that may be some handyman's idea of a way to connect a sink drain to the sewer system. "​
There is no trap below. This is the trap and it isn't a handyman special. It is a legitimate plumbing "fixture" from 40+ years ago. It works fine, except that it tends to collect gunk in the bottom that eventually fills up the trap to a level above the outlet. Then you have a problem, since there is no way to get a snake through it to clear it. Thus the invention of the P trap, I would guess. Another one of these I saw had a cleanout at the bottom. Good for a crawl space, bad for under slab.
Good start
You're getting there. Now bust up the floor over to the 4" and start over new,and to code. Still need ideas? That's why we're here! :)
Now why would I want to do that? What does the code say to make me bust up the rest of my floor?
Now that you have cut off the funny looking thing, take a band coupling and install a new p-trap.
You should be good to go then.
I can see the vent in the wall for the shower.
Thanks for adding the picture, makes a lot more sense now.
It looks to be going into the vent but I would assume it ties into the 4" someplace. I would bet if you dig down a bit and rerun the lines like to the 4" like toolaholic said. This is because That copper is old and should be upgraded and now is the time to do it.
....is the only vent or drain line. ....
true, that the weird thing you dug out of the ground was exactly as you described in this quoted paragraph. However, you had mixed up vent and drain beforehand, and the two previous posts had been confusing, so it still remains that things as you described them in general were self-contradictory until that point in time when you produced your second photo. It is not a drum trap. That pipe is not the vent.
As it stands now, I give you the highest respect for being able to figure out what things are and then to describe them in few words. Once you see them.
david
trap
I guess you would have to call it something between a drum trap and a P trap. In 55+ years of plumbing I have never seen a trap like that so it may be something that was used regionally in some parts of the country.
Sorry to Confuse.
Patrick88/toolhaholic - There is a sewer line in the wall were you can see the vent header. The drain line is connected to it.
Oh, and that line isn't copper - it's steel. If it was copper I would be cutting it all out, selling it and putting in PVC. :D
Plumbob - I just saw that episode of This Old House. A day late but interesting.
David - I'm a mechanical engineer, so I real good a designing plumbing on paper. Unfortunately, that doesn't mean I have had a lot of opportunities to to actually see the stuff I write on paper and I definitely don't get to install it. Doing my own home repairs can be a bit humbling :eek: So I come here to learn.:)
Oh, and that line isn't copper - it's steel. If it was copper I would be cutting it all out, selling it and putting in pvc. :D
I would be quicker to change out steel than copper any day. Steel tends to collect a lot of junk in the line, and rot out the bottom.
Nooooo!
Don't say horrible things like that :eek: The reason I am doing this bathroom remodel is because I don't want to spend a bundle. We are talking about moving in a couple of years and I want to at least get what I have put into the house.(the bathrooms have to be remodeled though. We are talking carpet, tiles falling off shower walls, etc.)
The drain line does have some crud in it, but it doesn't look excessively corroded. If anything needed replacing it is probably the main drain line and I am not digging into that (slab on grade, remember) unless the sewer gas starts overwhelming us. ;) Should that happen, I just may be stuck in far West Texas for quite a while just to get my money out of the house.
