View Full Version : removing scratches from new sink
Michaela521
10-19-2007, 10:50 PM
Hi there,
Got some scratches on my new stainless steel kohler sink. It was an expensive one too. Would a green scotchbrite pad with Bar Keepers Friend cleanser scrubing with the grain of the steel do the trick or should I use something else. Not sure if the green will make it worse or help etc. thanks
leejosepho
10-20-2007, 05:55 AM
I doubt the pad or BKF will have any real effect at all. Stainless is hard.
If your sink did not come with a bright, smooth finish, you might try some very fine automotive valve-grinding compound to blend the scratches in just a bit.
tonykarns
10-20-2007, 06:12 AM
If the scratches are not to deep you can use automotive rubbing compounds with super fine grit wet sanding. The sanding portion comes first and then to get the shine back the rubbing compound is used. The real trick is to make sure you follow the current grain of the stainless. If it is circular than you have to follow the circular patter. If it straight follow that patteren. Going across the stainless grain will make it look worse. It does take patience and some elbow grease but I have had good success with this method.
Hope this helps.
Michaela521
10-20-2007, 11:12 AM
Thanks, I got that info on how to remove scratches off of kohlers site found here http://www.us.kohler.com/general/faq.jsp
I figured I better get a second opinion though before I do something that might destroy the finish. Thanks:cool:
