View Full Version : Filter for hot water? (dip tube problem)
Maxx
10-10-2007, 04:47 PM
Just replaced a dip tube in my water heater, but the old crumbling dip tube broke off & fell to the tank bottom.
As a stop-gap measure (a few months or so, until I can replace the water heater) is it possible/prudent to install a filter AFTER the hot water, thus filtering out the large plastic chunks? (a sediment filter)
The particles are clogging up the faucet aerators, and I fear they may damage/clog my shower mixing valves. I think a hi-flow filter tat only catches large particles my work.
Will this work?
theelviscerator
10-10-2007, 04:51 PM
I could be wrong but most filters are not rated for hot water.
Maxx
10-10-2007, 06:09 PM
After checking, it seems there are high temp filters, but pricey (100.00 for the casing, around 30.00 per filter)
So it would be a fairly high priced band-aid.
But would/will it work?
patrick88
10-10-2007, 06:20 PM
If it is what you think it is. Yes it would work.
Turn the tank off and try to drain and flush it out. I would use a water heater pump that can be used to drain the tank and the turn it around and back flush it with a laundry valve, sillcock, or laundry sink faucet.
master plumber mark
10-10-2007, 06:23 PM
you cant get that out...
its nearly imossible to do that in a
efficient manner
its not worth the trouble to fool with...
you might be able to blow out a bunch
through the drain port with the faucet on
and under full pressure...
bite the bullet and put in a new water heater
before that old dip tube bites you back....
markts30
10-11-2007, 05:36 AM
Easier and cheaper - cut a "y strainer" into the hot line just after the heater - it will trap the particles and is made to be cleaned periodically....
Maxx
10-11-2007, 05:43 AM
Hmmm, sounds interesting. I am not familiar with that, could you explain?
Maxx
10-11-2007, 05:47 AM
After a little Googling, is this what a y-strainer is/looks like? ( or is it wye strainer? )
toolaholic
10-11-2007, 06:22 AM
After the big dip tube failures,and a class action suit: Plumbing conts. were
vacuuming out WTS .use a shop vac duct tape and pvc pipe. Myself ,I'd just replace wh
