Montalvo
On June 18, I asked this forum for some advice on replacing a water heater that provided DHW and radiant heat for my 7,100 square foot house. Based on the advice I got here plus a recommendation from a local installer, I had the installer put in a Phoenix gas-fired water heater/boiler from Heat Transfer Products at a cost of $12,900. It worked great until we got a small cold snap.
I turned on the radiant system for the first time today and as the boiler began to fire up, it abruptly shut down, displaying an error code "FLU", which meant a clogged vent (or a bad venting switch). I read through the installation instructions and discovered that the combined length of the intake and exhaust vent pipes can only be 85'. The exhaust ALONE is 85', when you take into account the friction loss of elbows which adds 5' of length for each.
I have a call in to the installer and fortunately I can rely on a forced air system for heat in the interim. But now that I look at the alternatives for venting this installation, I don't think it's going to be possible to install this unit at my house. So what should I be expecting from this installer? He's already removed and junked my leaky water heater. And at this point I think a unit like the one he installed or a boiler with an indirect tank would be far better than simply replacing the old water heater. But I don't want to get soaked for the cost of the improper installation that this guy has done and I'm not sure how to tell whether he's going to be burying cost recovery charges in whatever new solution he comes up with. And, needless to say, my confidence in his competence is more than a little shaken.
Can I ask for some opinions on what my expectations should be? I'd like to hear from those professionals who might have encountered situations like this with your clients. What would YOU do to make things right in a situation like this? And do you have any recommendations for high-efficiency boilers that could accommodate long intake/exhaust runs?
Thanks,
Bob
P.S. Here's my original forum inquiry if you're interested:
https://terrylove.com/forums/showthread.php?t=13748&highlight=montalvo
Thanks,
Bob
