View Full Version : Franklin motor parts
FLATFLAME
10-01-2007, 01:15 PM
Hey there folks,
I have a Franklin 5 hp submersible motor that hit the ground before setting in the well casing. as a result the bottom pressure compensating chamber has a crack in it. Does anyone know where I can get a parts list and purchase the part???
Thanks,
Flatflame
Bob NH
10-01-2007, 02:05 PM
I would not be happy to have a field-repaired motor in my well.
If it wasn't a Franklin-repaired and warranted repair I would want a new one.
You might check with http://www.wwpp.us/franklin/franklin-3-wire-motor.shtml for a new motor.
http://www.franklin-electric.com/Subm_text/ussrvc.htm
http://www.franklin-electric.com/Subm_text/subsrvc.htm
FLATFLAME
10-01-2007, 02:13 PM
Thanks Bob,
I'll send'em a message
Tony
speedbump
10-02-2007, 06:40 AM
You more than likely damaged the thrust bearing in the bottom of the motor also. I had it happen to two 3hp motors in a row. I didn't know they had been dropped, but put them both in a well and had to pull them in less than two weeks.
bob...
