View Full Version : Has anyone seen a drain configuration like this ?
Jeff Nolan
09-29-2007, 03:58 PM
Hello,
Has anyone seen a drain configuration like this ? I have a PVC toilet flange that goes into a 90 degree PVC elbow. The strange thing is, I then have a 1.5 inch PVC bathtub/shower drain pipe connecting directly into the 90 degree elbow (for the toilet) via a female fitting in the side of the 90 degree elbow.
My concern is whether this is "up to code" or should I remove this setup in favor of another configuration. Our house is approx 17 years old. It's worked for the last 17 years, so I probably shouldn't worry, but a failed wax ring forced me to rip the subfloor off and while I'm at it I might as well do the job correctly. (the bathtub has it's own trap underneath the bathtub drain so rising gas isn't a concern... just toilet solids potentially clogging this Toilet/bathtub elbow connection.
Any thoughts would be greatly appreciated
Dunbar Plumbing
09-29-2007, 05:36 PM
This used to be code in my area 30 years ago but the problem with that configuration is when the toilet flushes, it has the capability to suck the trap dry on the lavatory or tub drain.
In my state of KY, every drain must have a vent and the drain must be vented before it connects to another branch which that receives waste water.
Livin4Real
09-29-2007, 06:07 PM
Is the 1 1/2" coming off the 90 the vent for the toilet maybe?
patrick88
09-29-2007, 06:11 PM
It sounds like it is stack vented and this was a very common way of doing things. If it has worked in the past you can keep it this was.
Jeff Nolan
09-29-2007, 06:19 PM
Thanks Livin4real,
Unfortunately it's not the vent but the drain for the bathtub. I've filled the tub up with water pulled the drain and watched the water flow out of the 1 1/2" and into the 90 elbow.
Jeff Nolan
09-29-2007, 06:24 PM
Thanks Rugged,
I'm here in Illinois and evidently this was code 17 years ago. I checked again and there's a Y connection about 2 feet down the line from this strange elbow setup that leads to the vent.
Would you reconfigure this or leave it the way it is ?
Thanks again for your help !
Jeff
Dunbar Plumbing
09-29-2007, 07:10 PM
If you got open access to this....I would change it. That way it is a memory and you don't have that worry to contend to down the road.
Sometimes when you flush the toilet....the waste from the toilet and can get into this branch..and the sink can slow up/clog as a result. I've unclogged a few in this way being extremely careful knowing a lot of these in the older neighborhoods were all lead.
Jeff Nolan
09-30-2007, 06:21 AM
Thanks Rugged,
It looks like my only option would be to have a stand alone 90 degree elbow going to the toilet ...then about one foot downstream a "Y" connection that goes to the bathtub... then about one foot further downstream from that would be the existing "Y" that goes to the vent. Do you think that would remedy the problem ?
Jeff
09-30-2007, 06:57 AM
A side, or heel, inlet elbow was NEVER allowed in the Chicago area, for either a drain or vent, but might have been okay in the rest of the state.
