Water Hammer and Washing Machine
wanderinh
Hello Everybody on this Forum. A few days ago I installed metal braided hose to the hot and cold water faucets of my washing machine. I inadvertently did not open up the cold faucet all the way, and since then, I have done 2 loads of laundry.
I am now experiencing Water Hammer when the washing machine operates. It has not occurred before this ever. What are my options at fixing this. Will running all the faucets and flushing the toilet a few times assist in releasing that air? Will an arrestor work? What are some options before further damage occurrs?
At the same time one of my other bathrooms is currently in the midst of a remodel and no bathroom activity has taken place there in some time.
Any advice or recommendations will be appreciated and considered. Thanks for your time and help.
Sincerely,
A plumbing system in need of some help.
If you had air in your water lines you would know. The air would blast out of your faucets as air.
The ploblem is the new hoses you installed. The hoses you tend to find are a bit under sized and your washer machine has a fast closing valve in it. You did not have a problem with the old black hoses because they were all rubber. You have three choices.
1. Put your old hoses back on, or get new older style black rubber hoses.
2. Install hammer suppressors
3. Get better bradded hoses that are full sized and and have rubber in the I have the 3/4" brass craft bradded hoses on my machine and have never had problems and that all I install on houses I work in.
AT least a couple companies sell screw on hammer arrestors especially for the washing machine. they cost about $12 each at the big box stores. No tools required, just remove the hose, install the thing, then reattach the hose. better hoses might also fix it.
Thanks
Thanks for the advice. I am going to return to the original rubber hoses I have and when I have time, upgrade to larger metal braided hoses. Thanks again.
The washer should have the hammer arrestors anyway.
Old black hoses may not have hammered, because they may have been expanding with the back pressure of the hammer.
Old hoses burst occasionally and cause water damage.
Or, it could be something as simple as opening up the valves all the way.
You may have a loose washer that is fluttering as water goes by.
Does it hammer as it fills, or when the water shuts off.
