Boofuss60
- Messages
- 3
- Reaction score
- 0
- Points
- 0
This problem has developed in our water system which I believe is due to air in the plumbing lines. faucets and particularly toilet bowls refilling are very erratic, and noisy. The water is very foggy--but the hazy color dissipates--I believe this is from tiny bubbles.
I know very little about plumbing. But I did notice that next to my submersible well is a large fitting -- which I believe is a pressure release valve and it is slowly dripping. I know that when I bought this house a year ago it was NOT dripping and the current problem did not exist. So I covered the outlet (where it was dripping) with plastic wrap tightly rubber banded (to stop, or minimize air travel in/out). This seems to have temporarily fixed the problem.
Does this make sense? This valve is before the pressure tank. The leak is slow and seems unlikely to cause all the erratic water behavior in the house, but maybe so--I really don't know. I've attached photos. Would someone please confirm this test, or educate me? The valve says 75 (psi pressure I assume) on the side. If it's the culprit--do I need it?
