View Full Version : GU10 type bulb dimmer
ddagsyn
09-27-2007, 08:51 AM
Can the GU10 type light bulb be used with a dimmer
Thanks
jimbo
09-27-2007, 12:42 PM
GU10 is not a bulb type, it is a base type (Twistline). Typically, you would see this on a halogen bulb, which can be dimmed if you get a dimmer with the appropriate voltage and current rating.
Here is an example of a bulb:
http://www.prismaecat.lighting.philips.com/ecat/Light/ApplicationRouter.aspx?fh_secondid=924780636377&fh_eds=%c3%9f&fh_location=%2f%2fprof%2fus_US%2fcategories%3c%7bf nppla%7d%2fstatus%3e%7bact%7d%2fcountries%3e%7bus_ US%7d%2ftecpr_19%3dplc_509%2fcommercial_family%3e% 7bfnppla_H_TWIST%7d%2ftecpr_19%3dplc_509%2f_rated_ lamp_wattage%3e%7bplc_371%7d%2f_bulb%3e%7bplc_999% 7d&fh_refview=lister&tab=&family=&&left_nav=us_en&
frenchelectrican
09-27-2007, 04:56 PM
The other thing about the GU-10 bulb type that come in line voltage and low voltage but here a catch i am sure most will know this but i will remind again with low votlage system make sure you have the right low voltage dimmer they come in magantic and electronic verison.
just a head up with this.
Merci, Marc
ddagsyn
09-28-2007, 06:13 AM
thank you guys. One more question if the light I need to dim is on a 3 way switch which end can I connect a dimmer to?
Thanks
09-28-2007, 06:23 AM
Either end will dim the bulb, put it where it will be most convenient to use it.
Spaceman Spiff
09-28-2007, 06:41 AM
They do make three-way dimmers.
And, given the right budget and equipment, almost any lamp can be dimmed. This includes arc lamps and flourescent lamps. Flourescent lamp dimmers can now get down to 10%. It's pretty cool to see a 4' tube just barely glowing...
jimbo
09-28-2007, 07:43 AM
In a 3-way, be sure to get a dimmer designed as a 3 way. Otherwise, one the other switch wil just give you on/off/.
