raj639
03-09-2005, 01:18 PM
Two questions.....
1) I have installed a new drain trap under the kitchen sink and the difference is that the cones do not seat sufficiently between the new trap and the main drain pipe. It seems that there are two slot openings in opposite sides of the ring nut where the small flanges in the trap prevent the ring nut coming off the trap itself.
Without changing the main drain pipe, which would be difficult based on the location under the sink, is there a way I can seal those two openings to plug the leak. I can remove the trap, so what I would like to do is remove it, drain the water, connect the trap back again then apply a sealant where it leaks. What is the best sealant to use to stop any more leaks?
2) I also have a leak where the pipe from the disposal connects to the Tee with the baffle in the main drain. The pipe has a flat plastic gasket, but I cannot tighten it up enough to seal the leak. Should I place a rubber washer between the two surfaces?
I suppose I could continue to keep tightening, but I am very leery abot over tightening and causing the nut to crack. It has happened to me before which meant going out to purchasing extra parts and redoing the whole thing again.
Any advice would be appreciated.
