One I just installed had a trim ring held on with a friction fit from an o-ring. Another was a snap fit. It had dimples on it that aligned with small slots in the flange, and you could turn it a little bit to essentially wedge it on tight. The o-ring version could have the trim ring pulled away from the wall by just sliding it (it might be easier with prying it slightly). The snap fitted one would likely be a pain to get off, since you had to align the tabs, then pry it off.
