We have a 1939 home that had some ancient galv supply line that had constricted the pressure a lot... so we replaced it with the black poly. That worked fine, but we ran into a problem when hooking up to the meter because there was a copper line (a size not quite 3/4" as a solder fitting has way too much slop around it, but not 1/2" either) got cut.
There is what seems to be a 1" fitting on the meter itself that we can connect to, but the union like end that fastened this copper to the meter has a slightly different thread and a gasket in it.
For a short term fix, we connected a new galv 1"x3/4" coupling to connect our new waterline to the meter... which works, but leaks just a bit. Does anyone have an idea of where to get a new part that connects directly to the meter? The local plumbing contractor supply didn't have anything.
The other problem (in addition to wanting to fix this the right way), is that for some reason when we turned the water back on, the cold water at the lav barely drips, though in the rest of the house it's at different levels of slight restriction. Is this a vacuum lock or is it dirt/etc that came in and is blocking the plumbing?
Thanks for the help!
(Note: Tried to upload a picture of the part, but too large. Let me know if you'd like to see the part and I can email a picture to you)
