missing
03-07-2005, 11:35 PM
hello,
i am re-plumbing the pipes under the kitchen sink. the house was built in 1946, it is a double sink going to a single wall drain whick terminates into a leaded galvanized 2 inch pipe into cast iron.
from the bottom of the sink to the drain is 5 inches, the kitchen drains are 18.5 inches apart from center to center. i have tried all kinds of screw together pvc fittings to drain the sinks. no joy, they all leak. i replaced with glue together pvc, 1.5 inch, all is fine, except at teh tailpiece on the drain closest to the service drain into the wall. i screwed it down snugg and water then leaked from the tailpiece and the part that is screwed to the pvc glue joint. i thought okay, try another piece, no joy same thing. any suggestions would be appreciated at this point. is there a way to glue a tailpiece of pvc to the bottom of the sink and remedy this problem, or do i need to tear into the wall and replace the pipe to a level that all the drainage is farther downhill. thanks in advance. i have pictures if that would help.
