View Full Version : Pipe for exterior gasline
jerseybob
09-17-2007, 11:15 AM
We have propane to heat our house. I want to connect the gas grill to the mainline. I would be running the pipe under the deck to grill using a quick disconnect from the end of the pipe to the grill. I would use a gas cock at the end of the pipe run.
I have two questions.
1. What type of pipe should I use for the exterior line, galvanized, black or something else?
2. Is there such a thing as a quickdiconnect hose that is flexible, I mean flexible like an air hose, not the typial gooseneck connection on a stove or dryer.
TIA
In our area the gas companies use copper or the yellow coated stainless. Yes there are flexible lines, like an air hose, available.
You may be best advised to let your local gas company do the job.
jadnashua
09-17-2007, 12:06 PM
www.mbsturgis.com (http://www.mbsturgis.com) sells some nice hoses and quick connects. They sell direct and are the supplier to some of the better grill companies. I bought one from them for a new grill install.
Why is ther no discussion of the dangers of flex line for an exterior application that PEW said his local gas companies use? Seems like that would be quite dangerous.
Also, Is it allowable to run black iron outside (along the bottom of siding, or under a deck like in this instance)?
As for black steel being used outside...It is done all the time in my area. It IS necessary to paint the steel pipe to keep it from rusting.
Marlin336
09-17-2007, 04:41 PM
Check your local codes for running black iron outside. Around here is has to be galvanized or trac-pipe.
Wet_Boots
09-17-2007, 06:25 PM
Galvanized pipe for gas? I never see that.
trac ipe outside seems dangerous as it is easily punctured.
GrumpyPlumber
09-17-2007, 07:41 PM
We don't either, on the idea that the coating can fleck and clog the fixtures, but in other stes black is as ludicrous to them, because using black outside has to be painted.
There are three conditions the have to be met all at once for sheilding CSST - when it's within 3 inches of a nailing surface, hidden from view & clipped or passing through a hole where it can't flex.
Galvanized is the requirement here for exposed lines, although the utility uses black and paints them. Flexible gas line either has to be buried 24" or encased in a protective sleeve.
Rancher
09-18-2007, 08:44 AM
I would be running the pipe under the deck "under the deck" is that is a concrete deck, then the pipe needs to be inside a 2" pvc pipe and vented.
Rancher
What kind of paint do they use to paint the black iron?
Molo,
Propane companies in our area will provide a short flexible hook up from the regulator to the grill. If memory serves me right, they are about 8 feet long and will allow the grill some movement on a deck or patio. Looks like a slightly oversized air line.
toolaholic
09-18-2007, 11:25 AM
Where I live ,NO gas under deck . No gas undedr concrete
jerseybob
09-18-2007, 12:17 PM
The deck is wood and open from underneath, the underside is about 2 feet above grade.
I'm in central New Jersey. If I can't use black pipe nor galvanized what other options are there. Should this even be done at all? I know of other people in my area that have done it, it doesn't mean they have done it by code.
Check with your local codes, I would be very surprised is black iron, or galvanized would not be acceptable. I have seen both used by propane gas companies in Delaware / Maryland both indoors and out.
There was a time that nat gas required black pipe. From talking to an engineer at Phila Gas Works, that time has long passed us by. But, you will still find areas of the country which have not written black pipe out of their codes for nat gas.
FredC
09-18-2007, 06:05 PM
Under my elevated wood deck in Georgia the gas company used copper on the that attached to the underside of the joist, away from the nailing surface. About 3 feet from the end, a flexible poly line with 2 compressor like fittings that came with the grill we bought was attached. The line was only 8ft long and offered a little movement for cleaning the deck but not a much else. I would have preferred a rigid pipe under the deck with the same poly attach line, a valve, and one of those new safety flow limiters that prevents totally unrestricted flow.
FredC
construct30
09-18-2007, 06:15 PM
Anyone that has to ask should have a service person who knows about gas do the job and just assist him or her. Gas goes boom when people play with it.
mark
Just got off the phone with the local building inspector, he said 1" black iron, painted, is ok outside here. (ny state) (we only discussed 1", and he told me to secure it to the house every 24-32")
Rancher
09-18-2007, 07:18 PM
Where I live ,NO gas under deck . No gas undedr concreteWhere do you live? I specifically asked the building inspector how to do it, 3/4" black pipe inside a 2" pvc open at both ends and vented to the outside.
So I guess where you live there either are no slab on ground homes or you don't have homes with kitchens with islands that have gas burners.
Rancher
from previous posts, I believe he's in san fran
