View Full Version : laudry room drain issue... please advice
lcastro
09-17-2007, 10:43 AM
I connected the drain as per pic, it was working just fine, until about 3 weeks ago. How its clogged up. It appears that its just clogs up when the washer machine is running and draining its water.
I ran a snake through the pipe and and ran presure water down the drain and the water flow is ok, it does not clog up.
Any suggestions ?
Thank You..
GrumpyPlumber
09-17-2007, 12:30 PM
Any suggestions ?
Thank You..
http://www.terrylove.com/images/abs/abs_santee.jpg
Suggestions for what?
I will say the horizontal connection after the P-trap should have been a tee-wye instead of a combo wye.
Your post appears to state "..the water flow is ok, it does not clog up", not sure what the question is.
cwhyu2
09-17-2007, 12:49 PM
The discharge from w/m is pretty forcful.Make the tee lower absorbe some
the shock. Santee?
geniescience
09-17-2007, 12:50 PM
they should print arrows on fittings to show which way is up. Which way it has to go (up, down, ) to be used right.
- San Tees get used the wrong way around, and that doesn't provide a nice long smooth sweep for big water.
- Combos get used the other way around, and make 3/4 "S" traps.
David
cwhyu2
09-17-2007, 12:58 PM
I haveused santees on stand pipes ane never had aproblem as long as the
stand pipe is long enough,4ftfrom center of tee to washer box.
09-17-2007, 01:05 PM
Should have a santee instead of a combo.
http://www.terrylove.com/images/abs/abs_p-trap.jpg
The p-trap should not have such a big space between the two parts.
I would cut out the combo, use santee at a lower point, and make the standpipe longer.
lcastro
09-18-2007, 11:41 PM
Thanks for all feedback. I did some changes to the drain, however it still overflows slowly when the washer machine is draining its water. At first it sounds that water is flowing fine, then I can hear the standpipe getting filled until it start to overflow.
I've posted the first pic, then the second with the modified drain.
Please advice...
Thank You..
GrumpyPlumber
09-19-2007, 07:27 AM
You have blockage or a bad connection/undersized drain below.
I recall seeing a cleanout near the base of the drain above the floor, good move.
Snake it there.
