FredC
09-14-2007, 05:30 PM
For the Pro's on line
I have recently installed about 115 feet of 1 1/4" black pipe with 3/4' stub outs to my furnaces, stove water heaters and other accessories in my home and need to understand proper testing before getting the propane tank. I built and attached a test rig with a shrader valve and a pressure gage on a tee in the trunk line at the point of entry into my house. I have applied 40 PSI to all lines and blown out any debris from the installation process.
It is my undertsanding that you should put 15 to 20 PSI and hold for an hour. I put 20 psi on at 6:26 and just checked and am holding fine at 7:25. I will let it sit and check it in the morning, but am sure it will be fine. I had planned on getting into the attic to soap all the joints tomorrow, but am not sure how far to increase the pressure. I know propane and natural gas run between 1/2 PSI up to 14 inches water column.
So my question is holding 20 PSI overnight good enough and what pressure should I use when I soap the joints in the morning. Thanks in advance
Fred C
Fred C
