View Full Version : new svc line black PE
gfe76
09-13-2007, 07:22 AM
Live in Atlanta,GA. Will install new 1" service line with black PE 200 psi about 100 feet from street going into basment. Will bury about 16". Can I bring the PE into the basement and connect to my copper line or do I have to connect to copper from basement a few feet outside basement? What type fittings on black PE? stainless compression? metal bands (2 opposing)? what is torque on metal bands? thanks
Also do I need to put black PE in a PVC sleeve, or can I just bury it as is? I will make sure to remove rocks before burying.
GrumpyPlumber
09-13-2007, 08:35 AM
Here we make the connection inside the house.
You need to check local plumbing code as far as what's acceptable for a mechanical connection.
What seems odd here is that whenever I deal with a local water dept, they ask if I'm licensed...have you looked into this?
The reason I ask is that most plumbers will charge more than the initial price for work done prior to their arrival, be sure not to paint yourself into a corner.
Wet_Boots
09-13-2007, 10:13 AM
A waterworks compression fitting is your best bet. They will have a stainless insert for the poly tubing. Sleeve the line going through the foundation wall.
gfe76
09-17-2007, 07:04 AM
thanks for all the help. what is a waterworks compression fitting? thanks
Wet_Boots
09-17-2007, 08:23 AM
http://www.fordmeterbox.com/catpdfs/JJPEG.pdf
Gary Slusser
09-17-2007, 01:08 PM
Or use the normal SS or brass insert x male or female fittings for PE and two opposed SS hose clamps. This assumes you are allowed to run the service line from the street.
