View Full Version : slow leach lines
tlbwat
03-07-2005, 11:58 AM
The last time we had our septic pumped, the man said our leach lines were clogged, causing them to drain slowly. Any advice on what I can flush down there to clear them and allow them to drain faster? :(
jadnashua
03-07-2005, 05:41 PM
new leach field? My unprofessional opinion.
King3244
03-08-2005, 10:27 AM
How would the guy who pumps your tank know that your leach field was clogged? The most he can see is the discharge pipe to the field.
RioHyde
03-08-2005, 04:04 PM
If in fact your leach field is clogged up its probably clogged full of mud. I dont know of any way this can be cleared short of replacing the leach lines. Not saying there might not be a trick or two out there, but if a leach field has failed I recommend replacing it.
aceto
03-08-2005, 08:01 PM
I would check your distribution box. My septic tank lid failed this fall. The contractor had me pull the top of the distribution box and I was amazed at the soap residue and other crud that had collected there. This might give you an idea of how bad you really are.
King3244
03-09-2005, 08:43 AM
Definately look in the distribution box!
But I ask again.....HOW does the guy who pumped the tank know that your leach field is clogged??????
Does he have x-ray vision? :confused:
