View Full Version : low water pressure supply
ultraman99
09-11-2007, 12:38 AM
recently i had to raise the solenoid valves for my backyard due to drainage issues in the box. after i raised the valve set, i tested the sprinkler system. water was flowing out of the all sprinkler heads, but not enough water pressure to make them pop up. i looked around for spots in the yard for pooling, but no luck. my front yard and back yard share the main line and the front yard sprinkler system has no problems (front and back yard are 2 separate systems, just sharing the main water supply line).
i diverted the water supply to the solenoids to take a look at the water flow out of the line, and didn't seem like enough water was coming out, lacking volume/pressure.
i'm at a loss...what should i check for next?
thanks in advance!
Schulze
09-12-2007, 04:55 PM
Water was flowing out of all the heads...at the same time?
ultraman99
09-13-2007, 12:12 AM
no, all the sprinker heads for each zone. i checked if all the sprinker heads were running at the same time to see if the controller was bad.
Wet_Boots
09-13-2007, 09:20 AM
Sprinkler valves are waterproof, so why the changes? Was this trip really necessary?
ultraman99
09-13-2007, 12:10 PM
the water level was getting too close to all the wiring, so i decided to raise the solenoid valves as a precaution.
Wet_Boots
09-14-2007, 05:05 AM
Wires are waterproof, and there are waterproof wire connectors. Had you used them first, you'd have done all that was needed. You might as well take it all apart and test each valve, then rebuild it correctly.
jimbo
09-14-2007, 05:14 AM
You say you "diverted the water supply for the solenoids" and it was low. If this means you checked the water pipe before it got to all the valves, and it was low pressure/volume, then we have eliminated the valves as the problem. You need to look back. Is there another valve, manual or electric, which controls supply to the sprinkler system?? Do the sprinklers take their supply from the house side of a regulator valves? if so , some pressure gauge readings with flow/without flow will be instructive.
ultraman99
09-14-2007, 09:30 AM
yes i checked the water before the piping. there's only one valve before the solenoids, it's a manual ball valve. that ball valve supplies water to both the front yard and backyard sprinklers. the front yard has no issues.
ultraman99
09-14-2007, 11:15 AM
i found the issue. there was some blockage in the water supply line at the T going to sprinkler supply. thanks for reading my post.
