drilling sink?
jrseaberg
central IL
I just purchased a porcelain sink that was made for a single hole faucet mounting.
Is it possible using a diamond core bit to drill two additional holes for a 4" spread faucet (like you can drill a hole in porcelain tile)? Or will the vanity most likely break/shatter?
Jim
p.s..... I am going to ask this question on www.johnbridge.com too. I am a believer in the more opinions I hear, the better the chance of getting the right answer!:p
Not advisable. While potentially possible, you will have a high likelihood of cracking the sink. Any chance of buying a low priced single hole faucet? They can be had relatively cheaply. If it were mine I would buy the proper sink or the proper faucet, and would not drill new holes. Corian/solid surface is a different story, but you indicated you have porcelain.
How about returning the sink in exchange for a 3-holer? Or returning your faucet in exchange for a singler holer?
Not A Good Idea
you can probably drilll that porceine,..
but in time ....hair line cracks will probably
develope near everywhere you drillled...
you will nootice littel faint brown lines or streaks
brancheing out from "ground zero" at each drill point
you make in the sink...
they will get darker and darker and eventually your wife
will not allow the sink to stay in your home any longer
we had to appease a builder one time and drilled his special
sink.....warning him that it was not a wise move,,
and a few months later we get the blame for the cracks
that appeared in his sink...
correction!
Thanks for the input everybody!
However, the sink is ceramic, NOT porcelain.
Chassis, sink is what wife wants (size, etc.), but not finding a single hole faucet she likes. Sooo, unless I find "proof" that it won't work.(my hope is that I will have to tell her to buy a new single hole faucet)... trying to keep her happy!;)
Drillable? Yes. (Thanks, David)
Mark, still not a good idea? Cracking?
Jim
regardless of how careful you are, you will mess up the glaze. When the things are fired, they can develop stresses from uneven heating/cooling. SOme break during this process, but adding a new hole can be a problem. A tile will sometimes break when you drill it, too. They are relatively flat, and therefore don't have thicker/thinner/curved areas and are more likely to heat/cool evenly. Lot's of luck with the sink. You could get lucky.
Most manufacturers make complementary faucets in various styles, so it is surprising you can't find a single hole one to match the shower/tub. Personally, I prefer that type - much easier to get the exact flow and temp you want and quicker action, too.
