View Full Version : No water pressure on hot side in shower
PlumbingNewb
09-05-2007, 09:55 PM
I have the handle that goes around in a full circle from cold to hot in my guest shower. When I turn it to cold I get normal cold water, but when I turn it all the way to hot it basically shuts off and nothing comes out.
I have a washer/dryer 2 stories below this room and it seems that in the guest bath under this room it sounds like water is constantly running in the pipes. I can't find any shutoff valves etc. so I don't know what to look for. All the other hot water is working in the kitchen, guest bath, and master bath.
Thanks for your help!!!!!! :)
jadnashua
09-06-2007, 07:45 AM
It helps to know the brand and model.
If it is a pressure balanced valve (required on all newer construction), then the spool may be stuck. Can't say if it can be cleaned up and would then work or if it needs to be replaced. There may be other things going on here.
Explain more about when and where you hear water running.
BAPlumber
09-06-2007, 04:36 PM
with all your fixtures off, check the water meter to see if it's moving. if so, there is a leak somewhere. you can also turn off the valve at the water heater and see if the sound stops. this probably won't solve the "no hot water issue" but will get us going.
PlumbingNewb
09-06-2007, 08:14 PM
Thanks I'll try that. I don't think there is a leak though because my water bill is like $40 something a month and I take 2 showers a day so its not outrageous.
The shower handle on off looks like this:
I can't put a link so try this:
Moen Legend One Handle Chrome Shower Only Faucet
Model L3175
at home depot website
What should I do?
PlumbingNewb
09-07-2007, 09:22 AM
If I remove the handle is there anything you suspect I can turn to open it up behind the wall like a valve or something?
PlumbingNewb
09-13-2007, 07:54 PM
shamless bump... just need to know if I unscrew this thing if anything bad can happen and if I can actually get the valve open for hot water somehow even though I can't see one until maybe I open the thing up.
markts30
09-13-2007, 09:22 PM
Shut off the water and take the valve apart...
see if you can get the spool inside loosened up - use some plumber's grease on it...
If the innards seem worn, take them to a good plumbing supply shop and get some replacements... Buy genuine Moen parts... no knockoffs
PlumbingNewb
09-16-2007, 04:52 PM
:confused: ok I got the faucet off ok and behind the part you turn there are two little knobs you can turn with a flathead screwdriver. Should I mess with those? Maybe they are closed? There seemed to be a lot of drywall over one of these. I'm assuming they are hot and cold valves or something. What do I do??!!?!
patrick88
09-16-2007, 05:18 PM
They are built in shut off's for the shower valve. I'm thinking that whom ever installed the shower valve did not set the high limit for the valve. If the high limit is set to high on delta valves when you turn it all the way on the pressure will drop almost like if you went to far and your starting to close it again.
I would adjust that and i think this will solve your problem.
PlumbingNewb
09-16-2007, 05:26 PM
Thanks, I turned the right one and it turned the cold water off. When I turn the shower handle to hot, nothing comes out even when I turn the one on the left which I assume is for the hot water. The sink and everywhere else gets hot water. Should I open up the valve on the left that must control the hot water and try to clean it? There is hardly any room to do anything in there without breaking the tile.
That water running like I said above is only once in a while, may be my neighbors or something also, not sure. Its a townhouse.
PlumbingNewb
09-16-2007, 05:59 PM
Here is a pic of what I'm talking about, see attached
patrick88
09-16-2007, 06:10 PM
It is a pressure balance valve. You should have no water coming out if you turn the water off on either side it is a safety feature.
just make sure the hot is open all the way or if you are thinking of opening the wall make sure the water is off all the way hot and cold
PlumbingNewb
09-16-2007, 06:21 PM
I put it in the open position and every other position while the water was turned on and nothing comes out... What is the next step to try? Thanks
patrick88
09-16-2007, 06:49 PM
Do not open the valve unless you know the house main is off. On the new style single handle shower valves if you turn off one side and not the other the water will not come out no mater how much you turn the shower valve. It can fool you and is very dangerous. So to play it safe turn off the house main
All shut off valve are righty tighty lefty loosy.
PlumbingNewb
09-16-2007, 06:52 PM
Thanks, I'll make sure to turn it off. When you say open the valve what am I doing and trying to accomplish? The middle piece?
patrick88
09-16-2007, 07:02 PM
Sorry I just didn't want you to think that if no water is coming out it would be ok to open the valve as in take it apart.
PlumbingNewb
09-16-2007, 07:06 PM
It doesn't look like there is really room for me to take much apart there without busting tile. What would a plumber check next to see what the problem is?
patrick88
09-16-2007, 07:27 PM
The first thing is to make sure both hot and cold shut offs are on. The next thing to do is take the valve apart to see if something is blocking the flow. there really is not much to do about this unless you find that some valve (shut off) is not open all the way. Taking apart a shower valve can be very easy or very hard. Some valves can be fixed by replacing one piece some many pieces. Can you tell what brand the valve is. Sometimes the manufacture will send you new parts free.
PlumbingNewb
09-17-2007, 02:55 PM
I'm not really sure where to go from here to take the valve apart. I'm sure you guys would know what to do... What should I try to do? Snap off that HC white piece of plastic or what? I have no idea what to do with this
Thanks!!
PlumbingNewb
09-17-2007, 03:34 PM
What brand do you think this valve is? Maybe their website may have more info if someone can help me with that
markts30
09-17-2007, 03:46 PM
Check these links...
http://www.moen.com/shared/pdf/instruction_sheets/INS162E.pdf
http://www.moen.com/shared/pdf/L3175pt.pdf
PlumbingNewb
09-17-2007, 04:24 PM
I pulled that little U out of the top there, but I am having a lot of trouble getting that plastic part out of the middle.
cwhyu2
09-17-2007, 08:15 PM
Moen makes a tool to remove cartrages not cheap.Two different kinds P/B
and non P/B.You need P/B remover.
PlumbingNewb
09-17-2007, 08:18 PM
I yanked the catridge out with pliars and it didn't rattle like a spraypaint can when I shook it. It looked like one of the rings was missing and the side rubber piece was broken and may have been blocking the flow. I got a new catridge and its fine. Thanks for your help
cwhyu2
09-17-2007, 08:20 PM
Glad to be of help.
MoenMan
09-19-2007, 09:21 AM
It's a Moen Posi Temp 3570 with built in stops, you know to replace the cartridge. Call us today @ 1-800-289-6636 and ask for a 1222B Cartridge.
