Replacement window balancer?
Chassis
Engineer
SE Pennsylvania
I have single pane double hung windows, they are original from when the house was built in 1950. The balancers are steel coil springs about 18-24 inches long, and are accessible without tearing the window jamb apart.
I have a few of these springs that are broken, would like to replace them. As far as I can tell, the windows are "Curtis" brand. Couldn't find anything by searching on the internet. Can anyone please recommend a source where I can order the replacement balancer springs? Thanks.
I have never seen a balance that was not replaceable. I can't picture yours from the description. But the fact that you know it is a steel coil means you have some idea what it is. Almost always the balance can be removed by screws, if it is a steel wire wrapped in a spring coil,....or the springs are accessible by removing an access panel. You might have to look closely as the screws may be heavily painted over.
Some pictures would help.
I have an acct. with C L R ,GO TO THERE ON LINE CATALOG
They will sell to you. They supply all the glass shops
