Roshe
03-04-2005, 05:02 PM
Greetings.
I'm about to install a water heater(electric) and have questions about the flexible copper connectors(HD and most local plumbing supply stores have them). Do I need one on both the cold water inlet and hot water outlet?
The ones I've seen have what looks like a hose pipe connection with a rubber washer in the threaded end. If this is used on the hot water outlet, can the washer handle the heat? Also, would the stainless flexible connectors be better? Thanks for any comments. Roshe
