Hi, I am remodeling an upstairs master bathroom and am a little bit perplexed about how to handle the following situation.
I am installing a tile shower and directly across from the shower will be the toilet. Both the shower drain and the toilet flang are in between the same joist. The main 3" line is coming in just slightly below the joists almost exactly in the middle of both drains.
What is the best way to connect both drains? I was thinking about using a double sanitary wye. Will this work or is there another fitting or combination of fittings that would be better?
I greatly appreciate any advice.
Thanks
Thanks
