dbump
I haven't found any detailed info on laying out PEX for a system that can be gravity drained for winterizing. Any tips from those who have done it, or any links?
I'm mostly interested in the long trunk runs. I'm planning a hybrid remote manifold system with two, 20' long, 3/4" runs to manifolds at fixture clusters, all in a crawlspace. I could cut progressively thicker shims and use those at joists to space j-hooks lower and lower, but I'm concerned about the PEX drooping between clamps and retaining water. If I use clamps at closer intervals, I think it will make it harder to use pipe insulation effectively.
The only alternative I've come up with is to fabricate a constant slope substrate to fasten the PEX to. Possibly something as simple as a taut guy-wire. The PEX could be fastened to that simply with a spiral wrap of tape, and insulation would wrap around the entire package nicely. However, it's not exactly conventional, and I have no idea if an inspector would approve.
Regardless of the method, I'm also concerned about how to leave slack pipe for expansion/contraction, while maintaining a constant drainage slope.
--David
--David
