Tjbaudio
3 or 4" PVC to 4" CI and more? finished photos!
This is the main stack going out of my house. It looks to be 4" CI. I plan on redoing the rest of the house in PVC. At the same time I am going to low flow toilets. Total units in the house are: 2 toilets, 3 vanity's, clothing washer, dish washer, kitchen sink, and 2 showers. Should I use 3" or 4" PVC. I know if you go too big with not enough water clogs can from from solids not getting washed away.
Also when connecting the PVC to the CI should I cut the CI and use a band or can I find some thing that will attach the PVC to the top of that T with the old washer drain on it?
I plan moving the 2" line from the laundry room to a Y on the upper horizontal run. Should I extend the current line up to the vent stack so that utility sink is vented or can I just cap it off? I could also leave it as is. Though right now it is at a bout a 45 deg slope. I could also put a trap on it and use it for the furnace drain and plug the other hole. Thoughts?
At the other end of the house is where the bathroom and kitchen tie in. Right behind the toilet is an opening for the pipes to the up stairs and the vent to the roof. I have the option of doing it almost any way I want but I do need to conserve some space. I plan to run 2 3" lines up. One will be the vent the other will be the drain for the upstairs bath. I was going to have 2 y's and 45's in a line to get the pipes closer for the vertical run. One will exit the roof the other will make a 90 to the US bath. What order should I do? From the toilet to the first Y is 2 ft. Should the first Y be the vent or the US drain line? After that will be a Y for the kitchen and bath with a clean out.
Thank you for all your help.
