View Full Version : Septic connection
srob
08-09-2007, 06:58 AM
I having a new home built and will be installing the septic tank myself. When the basement walls were poured last week, the contractor placed a piece of sdr-35 sewer pipe in between the forms. My question is how do I connect my pipe coming from the septic tank to this. There is no hub or anything sticking out to glue to. Can I get that short peice of pipe out now that the concrete has hardened somehow? I have seen there are sleeves that can be put in the forms that allow you to shove pipes in from both sides and glue, but this is just a regular 4" peice of sdr-35. Any help would be greatly appreciated.
GrumpyPlumber
08-09-2007, 08:36 AM
well...it should have been a 6" pipe through the slab as a sleeve...then the
4" would pass through it and be sealed water-tight.
You're supposed to leave 1" annular clearance for any piping that runs through the foundation to compensate for expansion/contraction.
You might want to ask your contractor.
srob
08-09-2007, 09:37 AM
How is this usually made watertight between the 6" and the 4". Quickrete or something else?
GrumpyPlumber
08-09-2007, 09:56 AM
NOT quickrete...that would defeat the purpose.
There are a variety of ways...one product called "Nova links" (if I recall)...but the best would probably be plain old silicone sealant, even tar...you need something that allows for expansion inside the concrete, outside the pipe, but is water tight.
Again, your contractor should have sleeved it with 6".
leejosepho
08-09-2007, 02:25 PM
Your best bet would be to find a company with a coring machine to come drill a larger hole in that wall ... and you might try backcharging the company that poured the walls.
GrumpyPlumber
08-09-2007, 10:28 PM
yup, but he should call the contractor first...contractor could say he wasn't given the option of rectifying it first.
Cass
08-10-2007, 04:59 AM
Absolutely correct
