View Full Version : Sink Drain
MaximAvs
08-08-2007, 12:51 PM
I'm adding a new sink to a basement bathroom. When the builder stubbed off for a sink drain, he mounted it a little low. So I want to do a 90 up and a 90 out to better line up with the sink drain (and to bring the 'p' trap off the bottom of the cabinet).
I hope this diagram helps
http://img408.imageshack.us/img408/547/sinktj3.jpg
As you can see the pipe is 1 1/2" ABS.
So is what I want to do OK, or will it cause poor drainage from the sink?!
Thanks for the help
Sean
jadnashua
08-08-2007, 01:24 PM
I think you can do that, but you don't indicate a vent...that would normally be going up from where it goes in the wall. How far away is the nearest vent?
markts30
08-08-2007, 03:36 PM
I am assuming the original roughin had a vent...
You cannot go up with the 90 like that - that is an STrap...
Best bet would be to go to the original santee with the vent... cut it out of the pipe and splice it back in 6 or so inches higher with some banded couplings....
That will give you the height you want without the STrap issue...
On the other hand, if the drain the sink comes off has waste from the upper floor(s) in it, you cannot use it to vent the sink and will have to take the drain line, sweep up into a san tee for the trap arm of the sink, then run a vent to the nearest vent (not drain) and tie it back in...
Make sure this tie in is at least 6" above the flood rim of any fixture the vent serves.
geniescience
08-08-2007, 07:33 PM
both posts above discuss things happening off the far right hand side of your diagram. Without knowing what you have over there, it's all just speculation. Can you draw that in too? You are good at drawing.
David
MaximAvs
08-09-2007, 09:34 AM
Here's a drawing with more info.
http://img521.imageshack.us/img521/3135/sink2im7.jpg
Hope this helps!!
Thanks guys
Sean
geniescience
08-09-2007, 09:47 AM
what happens between the far right hand side and the P trap? Nothing? Straight pipe? Only a P trap there? No other pipe visible? No vent coming down from above? No Tee? No Wye?
Or, is there a vent pipe (i.e. vertical) and a connection point, which the P trap runs into?
If not, then no you probably won't get anyone's blessing to run the drain as shown, since it drops before being vented. Several ways to work around this problem, if this is what it is.
David
MaximAvs
08-09-2007, 09:58 AM
Sorry about that!!
It just come out of the wall and into the 'P' trap
http://img49.imageshack.us/img49/4193/sink2pj1.jpg
Sean
GrumpyPlumber
08-09-2007, 10:04 AM
Just to restate what Markst said...maybe simpler...
Any time you drop a drain more than 45 degree's you need a seperate vent because the momentum tends to siphon the trap...emptying a full basin of water would likely suck all the water from the trap.
MaximAvs
08-09-2007, 10:36 AM
So would it be better if I used a 45 instead of a 90. Right now the wall is closed up, so getting to the main drain/vent would mean tearing the wall up, and I'm hoping to avoid that. I left a 12" opening in the drywall to attach this drain.
MaximAvs
08-09-2007, 12:22 PM
The picture I show is how it is. The main 2" line to the left is where the venting is. Everything after the 1 1/2" stub is what I want to do.
What it sounds like is that I can't drain a sink with two 90s. I'd have to ADD another vent above the stub out for this bathroom sink to drain.
I just don't see venting like that in the walls behind the sinks in other parts of the house. The simply enter the wall and drop into a main line along the floor, to where the main sewer stack is, and the vent is on the back end of the run.
MaximAvs
08-09-2007, 01:09 PM
I would think it would only siphon if the pipe ran at full capacity. I don't think there would ever be enough water in the drain to completely fill the pipe.
Jeff1
08-09-2007, 01:14 PM
Couldn't you just use a longer pipe coming out of the drain?
MaximAvs
08-09-2007, 01:28 PM
Here's a picture of the situation prior to copper and drywall. So the room is completed with an access hole where the stub out is.
http://img49.imageshack.us/img49/1028/drainyu0.jpg
So at the end of the stub I wan to add an 90 up and a 90 out to get it up and in the previous drawings. (That stub is about 20" off the floor)
Sean
MaximAvs
08-09-2007, 01:32 PM
I did look at that, but then the P-trap is really close to the floor of the vanity.
08-09-2007, 01:39 PM
Cut out the tee, and raise the trap arm pipe.
Or, use a longer tailpiece going into the top of the p-trap.
If you use fittings to raise the pipe before the p-trap, you create an S trap that will siphon the p-trap.
If you siphon the p-trap, your wife will be complaining that the bathroom smells.
Do you really want that?
MaximAvs
08-09-2007, 02:10 PM
Not that she will stop complaining about "bathroom smells":D :eek:
So Use a longer tail piece and a 90 to the stub!! Even though the p-trap will be pretty low in the cabinet?
Sean
jadnashua
08-09-2007, 04:23 PM
While it might impact the room you have, if I remember right, the drop can be as great as 24". That does leave more pipe surface area that could have crud accumulate, but you don't get that much in a bathroom sink I don't think...
