HDFAN1
08-06-2007, 07:36 PM
In the last three months, I have had my foundation repaired,( $13500. Ouch.)
which tore some plumbing loose.
Readers Digest version; Have repaired three MAJOR leaks under slab repaired so far. $3500.00 Ouch again.
When plumber did the leak test the first times, before all the leaks were fixed, when watching the water level in the toilet drain, it would come about 9 inches from the floor level of the slab, and that was all. No matter how many faucets were on full blast.
After much isolating & testing, I thought we got the last leak repaired last week.
But, as my luck goes, there is still a leak. Somewhere. But it is a very small leak compared to the first three. The water level came right up to floor level, and appeared to be staying there. However, after 15 minutes, it had dropped about 6-8 inches down from floor level in the closet bend.
The house is 30years old with cast iron plumbing for the drains.
My question is, is this leak anything to be concerned about? The two companies I have had out to do the repairs are both saying not to worry about it. That the system will not leak enough under normal use to ever cause me any problems.
I WANT TO BELIEVE THAT!
What do the experts here think?
