View Full Version : Old Brass Drain
sixfoot
08-06-2007, 06:58 PM
So I just demolished my shower that was built 50 years ago. It is in a basement on a concrete slab. The drain is made from brass. When I shine my light down the drain it is about 2 feet to the trap. I managed to get the brass drains' interior to come up about 6 inches. The drain does not come out. It is a slip fitting with a flange that stops at the lip. Anyway, I am planning to "pour" a shower pan with that thick black plastic sheeting. It looks as though I need to use this drain somehow so that I can tile the floor as well...Any Ideas???????Thanks.
sixfoot
08-06-2007, 07:01 PM
The whole drain and trap assembly is completely entombed in the concrete. There is no working room. The Drain itself is in good shape, however, and just want to be able to create a watertight floor with tile and the old drain. The drain does not appear to have any type of weeping....
jadnashua
08-06-2007, 08:19 PM
To do a proper shower, you need a clamping drain with weep holes.
If you're going to build a tiled shower, I suggest you check out www.johnbridge.com (http://www.johnbridge.com) they are almost exclusively devoted to showers and other tiling projects.
