View Full Version : Delta lav. faucets...opinions please
HDFAN1
08-06-2007, 04:26 PM
OK, y'all prolly know about the problems I had with my shower valve install. I have decided to put in the 1700 series Delta.
Now, the matching lav faucet ( 8" sprd., two handle) for the Victorian series, which is what the shower trim is, looks very appealing to me. However, before I buy it, I would like some opinions.
I looked it over today and I wonder if those little plastic snap connections with o-ring will hold up. I'm sure y'all know what Im talkin' about here, but just in case, her ya go. The supply lines that go to the cutoff valves are copper with threaded connections. The line that carries the water from the valve to the spout is what I am concerned with.
Are they all made this way? Will they hold up? How long?
Thanks in advance for y'alls patience. I am learning much here. Never attempted any DIY stuff before, and it's nice to have this place to ask questions.
Basement_Lurker
08-06-2007, 04:44 PM
I think what you are saying is that you are concerned about using a plastic flexible fixture supply tube with to go from your shutoff valves to your new faucet. Just install your new faucet, and use the flexible braided steel supply tubes (made by brasscraft) that are sold in any plumbing department. They are quick and easy to use, and they are pretty much the standard these days.
HDFAN1
08-06-2007, 04:54 PM
Nope, not what I am saying. Let me try and clarify. The supply line is not an issue, at all. What concerns me is the little plastic tube that carries the water from the valve body, once you turn it on, to the spout of the faucet. I have never put in a faucet with an 8" spread before, so I have never seen anything like this before.
Sorry if I was unclear on the 1st post. Hope this helps.
BAPlumber
I've installed a few of the delta widespread faucets and have never had a problem with the quick connect hoses from the handles.
Delta is my preferance for shower valves at this time. I don't like Pfrice Pfister or American Standard.
HDFAN1
08-06-2007, 06:12 PM
Thanks BA. Are all brands made this way?
master plumber mark
08-06-2007, 06:15 PM
Only Delta has the brains and innovation
tocome up with something that simple and easy
to use ...
the snap connections work great ...
you wont hav e problems
HDFAN1
08-06-2007, 06:23 PM
OK, then that's the way I'm gonna go.
