View Full Version : Joning CI to ABS...drip...drip...drip:)
cruiser
08-01-2007, 08:41 PM
I bought a ferco fitting to join these two but the cast iron has been underground for 80yrs and is a bit bumpy on the outside:) I tried to fit them together but the CI end keeps dripping water out.
I've tried to smooth the surface with a wire brush with little success,anybody got any ideas? Is there some kind of a leak proof sealant I should use on the outside of the CI?
Thanks all
Verdeboy
08-01-2007, 08:43 PM
Have you considered replacing the cast iron with PVC?
cruiser
08-01-2007, 09:20 PM
The CI has about a 15" run into a CI hub(elbow fitting). I've no idea how to get the CI out of the hub, would welcome suggestions!
Basement_Lurker
08-01-2007, 09:35 PM
Unless the surface of the cast iron is super bumpy or flawed in some other way, I don't think you should be having a lot of trouble. My best guess is that you are either not using the proper sized coupling or you are not tightening the clamp to the appropriate torque. Have you tried tightening the gear clamp with a ratchet? You can definitely get more torque using a ratchet than with a nut driver.
08-01-2007, 10:18 PM
If it's old cast iron, I use a mission coupling made for copper to cast iron.
The older sizing is 4-1/8", which is too small for most couplings.
BAPlumber
08-02-2007, 01:51 AM
If the CI has been underground like you said and is bumpy, you can lightly chip away at the bumps and that will make a smooth surface to join to.
master plumber mark
08-02-2007, 04:02 AM
When this happens to me I usually get out
my trusty can of PRO DOPE......its grey and very stickey
they have something similar to this at Lowes ..its very
cheap.....
Usually if you liberally smear the pipe dope on the cast
with your hand all around the fitting,
and then put a liberal amount inside the fitting it will
seal the gaps in the pipe very well......
when you tighten it back down some will squeeeze out
and it should put an end to the drip
cruiser
08-02-2007, 07:08 AM
Thanks for the ideas guys, I realy appreciate it. Would I find a mission coupling in Home Desperate? or is it more a speciality shop item?
Mike Swearingen
08-02-2007, 08:29 AM
A Mission coupling is also known as a no-hub coupling, and you should have no trouble finding one.
As for rough CI, you can use a variety of things to help seal it from pipe dope, to plumber's putty, to caulk, to plastic roofing cement, etc.
Mike
cruiser
08-02-2007, 10:07 AM
Thanks for that. The coupling i used was neoprene with a metal band on each end. This joint will be under concrete,should I be using a fully banded coupling or am I using the right one once I put some pipe dope on?
jadnashua
08-02-2007, 10:24 AM
You need a banded on above ground, the unbanded one under, so you have the right one. Make sure to backfill carefully to keep the ends aligned. Pipe dope sounds like the longest lasting. A piece of rough sandpaper might smooth things out a little, too.
Taking the cast out of the hub is tedious, but if you have full access not too bad (I'm not a pro, the last one of only two, I did took maybe 1/2-hour on a 4" hub). Find a drill bit the thickness of just under the width of the lead in the joint. Make swiss cheese of it all around the pipe. Work it back and forth a bit to loosen the pipe, then dig it out. You should be able to get all of the pipe, lead and oakum (oiled hemp) out. Finding the proper sized Fernco dognut to insert may be the harder task, but sometimes you are lucky and find the right one. They come in numerous sizes since cast is only sort of standard (the lead filling the gap isn't super critical, so the size of the hub isn't - as long as the pipe fits in and there's enough room to put in the oakum and pour lead in, they didn't care that much). Basically, then, the connection would be to insert the dognut, then push the new pvc into the hole. If you get the right exterior diameter for the CI, it makes a great seal. If it is too tight, you may never get it in, if it is too loose, it leaks, so specifying the proper size is important. I'm not sure, but I think I remember seeing them in 1/16" steps in the catalog, and you may only have one or two choices stocked locally.
master plumber mark
08-02-2007, 06:58 PM
a fully banded coupling is probably best,
it has more firmness to it
although I usually just use the fernco type because they
are more forgiveing when working with them
whichever you use , maybe you ought to throw
some concrete into the hole so it never moves and
makes everything more pernament
