Hello there, I've read several guides on this common repair online, and while I have the basics down, I can't seem to get my delta kitchen faucet to work exactly right.
It's a very basic Delta faucet that uses the #70 repair kit. I purchase all my parts from local hardware store Hardware Sales.
My problems:
1. I have a very difficult time getting the white plastic piece that has the "shield" shape to hold in place while I put the metal cap on. Should it be that hard to push down? It takes tremendous force to get the little plastic side-nub to go into the slot. The seats and springs are in the right place, so I don't think that's it.
2. Once I do get the white shield thingy seated, I have to tighten the cap-ring too much to stop the leaks, so much so that it makes the faucet handle hard to move. I'm talking about the inner brass / plastic ring on the cap assembly, that you can tighten with a spanner. If I loosen the ring, water leaks out the top of the assembly when moving from "off - down" position to either of the side positions. It's not a flood, but it's enough to be annoying.
Should I just buy a new delta faucet? This one has been here about 9 years. The pressure required to move the handle now bends the stainless sink tub too much to my liking, due to the cap-tightness necessary to prevent leaking.
Thanks for any help.
Kevin Statema
My problems:
Kevin Statema
