View Full Version : Tub faucet still leaking
StuRat
02-27-2005, 08:18 PM
Thanks in advance for your response. I have a 35 year old three knob tub faucet that leaked when I bought the house. I have replaced the stems and seats for both the hot and cold water and it still leaks. Any advice on what to try next?
Thanks,
Stu
jadnashua
02-27-2005, 08:49 PM
Where is it leaking from? Around the stems, through the tub filler, from the shower head, down the wall?
StuRat
02-27-2005, 08:50 PM
Through the tub filler.
Bob's HandyGuy
02-27-2005, 09:20 PM
Did you replace the seat and washer on the center diverter? ( If it has them.) A column of water remains in the shower pipe after use. If the diverter is leaking, it will drip even if the hot and cold valves are sealed. (Not a pro.)
StuRat
02-28-2005, 06:03 AM
The center diverter is fine.
02-28-2005, 06:09 AM
If the seats are correct, there is no reason for new washers to leak, so the problem may be with the seats. What is the brand of faucet. If it is the correct one, there may be a better repair for it.
