View Full Version : New shower drain into existing laundry drain?
jsr
07-26-2007, 05:41 PM
I'm planning to install a new standup shower stall on the same first floor as an existing nearby laundry room. So could I conveniently drain the shower into the 2" laundry drain line in the basement that pass right by the location of the new shower stall? I'd plan on installing a 2" drain pipe and trap from the shower unit and Y into the existing 2" laundry line.
Thanks,
John
BAPlumber
07-27-2007, 01:20 AM
Thanks,
John
if you can fit a 2" p-trap and still get 1/4" per ft. of fall, and vent it, it should be okay. the only other issue is if other fixtures tie into that 2" line.
If there was a tub or shower there before, there should be a vent already and you could tie into it.
FloridaOrange
07-27-2007, 06:21 AM
Where are you located? Florida code, which is loosely based on the international code prohibits venting a bathroom fixture with a non-bathroom fixture (2004 FPC 909.1). If you could get a vent in to service the bathroom you'd be good to go.
markts30
07-27-2007, 01:33 PM
I would check to see if you can tie into the drain - if your tie in is closer than 8' you might be out of luck (sudsing fixture)...
As well, you would have to vent the shower on it's own (use a combo on the drain line with a san-tee above it then vent out the top and swing the trap arm to the shower drain.)
jsr
07-31-2007, 06:10 PM
I'm in Connecticut. Thanks for your replies. Guess I'll rely on local authorities on the definitive word.
John
