View Full Version : Toto Drake/Distance From Wall
stymie
07-26-2007, 04:17 PM
I am considering purchasing a Toto Drake ADA with the elongated bowl for a small bathroom. I need to know how far from the back wall will the front end of the bowl be if the floor bolts are 13 1/2 inches from the wall?
Steve
jadnashua
07-26-2007, 05:20 PM
It's designed for the bolts to be 12" from the wall, so add 1.5" to the spec sheet's dimmensions. I don't remember if it is available with a 14" rough-in, if it is, it may fit and then it would be 1/2" less than normal. Some of the other models of Totos also come with 14" rough-ins. Keep in mind, some toilets actually move the whole thing one way or the other, some just put a bigger tank on. If they just use a bigger tank, it will stick out more.
07-26-2007, 05:54 PM
With a standard 12" rough, the end of the bowl would be 28.75" to 29" from the back wall.
With your rough of 13.5" expect the end of the bowl to be at 30.25" to 30.50"
Some like the Soiree, that can use a Unifit, can be moved back 2"
That would mean in your case, with the 14" Unifit it would be 28.5"
stymie
07-29-2007, 03:57 PM
Thank you both for the info...it looks like the elongated bowl will fit...Great Info on this forum...
Thanks again,
Steve in Ohio
