1.5" to 1.25" Drain Reduction
Molo
Cold New York
Hello All,
From the vertical main up to the sink drain:
Into the main 4" CI stack is 1.5" ABS. 1.5" ABS goes up into 1.25" galvanized. Galvanized forms a 90 and and goes into the kitchen sink cabinet (galv. only 6" on each side of the 90). From the galv. is 1.5" PVC up 20" to an AAV/ sante. The sante reduces to 1.25" P-trap. To sink drain stem.
1. Is there a problem with the 1.5" PVC running into the short section of 1.25" galvanized elbow, or do I need to change this galv. elbow t o1.5"?
TIA,
Molo
You should never reduce the size of a drain. It creates a bottleneck which causes clogged drains.
I know, I know, NEVER reduce the size of the drain. But when I bought all these parts 1/4" too big. I put a reducer on the galv. coming out of the bottom of the cabinet, and installed it. The galv does a quick bend in the basement and goes into about 4' of abs into the vertical below the toilet. I can fill the sink up and pull the plug and it drains fine. I can hear the AAV sucking air toward the end.
How does this installation look other than the sizing mistake?
How can you explain the good draining action? Is it the AAV?
TIA,
Molo
what the photo shows looks good. But you can't reduce after increasing the size to 1.5". You don't have a lot of options now. Either to redo that 1.5" part in 1.25", or to remove the galvanized (and the reducers), and run the whole drain in 1.5" since that is the size you are now at. (Use a long sweep bend). Either now or later, but later won't be nice and now is a nice time.
david
Here (UPC is code), the trap arm and trap of a kitchen sink have to be at least 1 1/2" tubing and the waste (starting at the santee where the AAV is) has to be at least 2"...
This is code minimum here...
it is a combo of `1.25 and `1.5. it drains like a beauty, like i said, a full sink drains down in a hurry, and i can hear the AAV sucking air at the end......
drain
The AAV "prevents" too good draining. If it were not for the AAV, you might have to hold onto everything within a foot of the drain or it would get sucked in.
Molo...I'm gonna hold my breath till you decide to put a 1-1/2" drain there.
It's a kitchen sink...I even rough 'em in with 2" when I'm doing new remodels because of future trouble with grease.
Yer askin' fer trouble down the road.
ok, it prevents siphoning?
aaV
That is the purpose of all vents. Without a vent, the drain speed is governed by how far the trap's outlet pipe drops before it has a source of air intake.
