View Full Version : Covering AC line set on outside of house
wlam08
07-24-2007, 02:56 PM
Does anyone have any suggestions for covering / dressing up the line set coming down the side of the house from an attic AC unit?
I have white siding and the black foam just pops right out at you....
jadnashua
07-24-2007, 06:04 PM
How about a gutter pipe? You can get them in aluminum, prepainted. You could cut a slit in the back side and slip it over the pipe. Some of the people are quite creative, so wait to see what other ideas crop up.
KennyDash
07-24-2007, 07:45 PM
How about rerouting or covering with plastic sheathing that you can match up to your exterior as close as possible.
Spaceman Spiff
07-25-2007, 07:23 AM
Call up someone who does aluminum gutter and soffits. You should be able to go to their shop with dimensions and get a custom braked cover and back flange that will cover the pipes. You screw the flange to the house behind the tubes then snap the cover on. All of it will be prefinished white aluminum stock up to 12' long per section. Crisp clean and should be at minimal cost.
gtmtnbiker
07-30-2007, 08:14 PM
Look for "slimduct" at your local supply house. Example: http://www.ductlessdepot.net/accessory_details-accessory-11-0-176.html
brownizs
08-05-2007, 01:04 PM
Is it really that noticeable from the street? If not, and the lines run from the unit to the house, leave well enough alone. Covering it up, allows for other problems to come along (ie critters nesting in the tube covering).
