View Full Version : Wall Hung Toilet "Saver Nut"
hosea
07-23-2007, 10:09 AM
Is there an on-line link which clearly shows how to re-mound my Kohler four bolt wall hung toilet? I am a little unsure how the "saver nut" works.
markts30
07-23-2007, 02:48 PM
What do you mean by "saver nut"?
mounting the WC is fairly easy - you only tighten down one of the bottom nuts snugly - the other is left hand tight...(both top nuts are snugged down)
hosea
07-24-2007, 10:21 AM
I read some place that I should tighten the two upper nuts and the lower left nut. The lower right has a "saver nut" that looks like a threaded washer with multiple holes so that it can be turned counter clock wise to snug up against the toilet bowl. It is turned with a nail that is used through the lower right hole in the toilet bowl. This is supposed to prevent the bowl from cracking. The lower right nut is then tightened only by hand.
So what I need is a link that explains this remounting process.
