I'm new here and also to the well thing so please bear with me. I have a well that is 25' deep with a shallow well pump. Last year I replaced the well pump because the one that was there burnt out. I have replaced the well pump pressure switch ( 40-60psi )twice thinking it was faulty. I have checked the pressure in my tank with no water pressure in it and found it was a little low and set it to 38 psi. I started everything back up and still the pump will not shut off at 70 psi. I have tried to back the nut off at the large spring to see if it would help but I just about took the nut off when it would shut off. Then problem was it would not turn back on so I returned the nut to it's original position. I am I missing something here? Any help? Thanks, Mike
