Molo
What's the best way to drill a hole in CI?
Molo
Molo
leejosepho said:For a large hole, I would use a bi-metal hole saw with a supply of air for cooling and blowing away the chips.
molo said:What's the best way to drill a hole in CI?
Molo
markts30 said:What is the purpose of the hole?
Why are you wanting to drill it?
Cass said:I'm curious also.....what is the hole for and how big does it have to B?
GrumpyPlumber said:...whatever ya do...don't try saddle fittings on drainage.
RUGGED said:I've never seen a saddle that didn't leak, both on the water side or drainage side of the spectrum.
They get used a ton on the DIY side of plumbing repairs. Any plumber using them should turn in their badge at the front door for non-compliance of codes.
master plumber mark said:the absolute most crazy thing I run into, is where some idiot drills a 3/4 gas pipe and puts a saddle on a
gas line to feed an outside grill .....
the all you got to do is touch that pipe while installing their new water heater and you are in
a mess.....
master plumber mark said:and of course ...
you cant force them to upgrade anything that is working just fine the way it is....
they think you are trying to con them into saveing their lives.
markts30 said:Saddles are not to code...
As well, they tend to be places for problems to start (clogs etc)...
They also introduce a point of weakness in the pipe - a place at which strain will crack the pipe in the future...
