View Full Version : Another ceiling fan problem
rburt5
07-10-2007, 10:29 AM
I recently bought a house with a remote control operated ceiling fan. Everything on the remote works fine. However, the fan is also tied into the light switch on the wall. The light switch will only turn the fan (and light) off. It won't turn it back on. Is there a simple wiring mix up, or do I need a different type wall switch?
Also, if I leave the wall switch in the on position and use the remote control to turn off the fan, it doesn't turn all the way off. It continues to hum and turn the blades very, very slowly.
SteveW
07-10-2007, 12:38 PM
Any chance you are using a dimmer switch as your wall switcy? I tried that with a remote-controlled fan and some of the fan's features did not work until I swapped in a standard wall switch.
rburt5
07-10-2007, 12:48 PM
It has a standard wall switch. However, the remote control has a dimmer built into it.
jadnashua
07-10-2007, 01:22 PM
Sounds like the control board may be bad. I'd call the tech support people at the manufacturer to discuss with them.
rburt5
07-11-2007, 10:09 AM
I called the technical support people and they said that my model of fan cannot be controlled by the wall switch. He said to hang the remote control beside the light switch. I'm just going to buy a new fan. Thanks for your help.
Rancher
07-11-2007, 12:39 PM
I called the technical support people and they said that my model of fan cannot be controlled by the wall switch. Thats a true statement, however that doesn't answer the question on why the remote doesn't turn the fan all the way off. Buy a different brand next time.
Rancher
