View Full Version : replacing old toilet, flange, shutoff
llcart
02-25-2005, 10:51 AM
I need to replace an old toilet, flange and shut-off valve. Is this something an average homeowner can do? I'm most worried about the flange esp because I have an old house... Also, I have a 14in rough-in, can anyone recommend a good toilet? I've heard Toto are good, but I can only find 1 14in rough-in on their web site and I'd like something with a bit more style to go with the other older fixtures
Thanks,
Desperate Homeowner
jadnashua
02-25-2005, 09:12 PM
I've seen homeowners that can't screw in a light bulb (or are afraid to), and others that do major remodels; hard to characterize an average homeowner. If you have reasonable mechanical aptitude, it is not that hard. If the flange is in bad shape, then it becomes a much bigger pain, something to consider if it is the only toilet in the house.
The Totos that use the unifit adapter will work on a 14" rough-in. It comes with the 12" version, but the 14" can be purchased for it.
My unprofessional opinion.
RioHyde
02-25-2005, 11:25 PM
lol you're right Jim. I've never heard it put quite so eloquently though....cant screw in a lightbulb! cracked me up...
anyway.......
Desperate Homeowner,
Have you already pulled the toilet and inspected the flange? If not, you may or may not have to replace it. All depends on what you find after you pull the toilet and inspect the flange. Also, the Totos with the Unifit adapter (http://www.terrylove.com/wc/unifit.htm)are a good choice. A bit "different" to install, but you cant beat those Totos.
llcart
02-26-2005, 03:39 PM
I haven't done much plumbing work, but am fairly handy so I"m going to give it a try. I had a plumber out who pulled the old toilet off and told me the flange was shot but that he didn't have the part to fix it and that it would cost me $300 to have him do it. Thanks, and hopefully I'll be back on to report success (or otherwise ask alot of questions on flange installation and unifit installation)
